Simulation-based Performance Analysis of a Medical Image-Processing Architecture
Cuijpers, Pieter and Fyukov, Alexander
UML 2.0 State Machines: Complete Formal Semantics via Core State Machines
Fecher, Harald and Schoenborn, Jens
Heuristics for ioco-Based Test-Based Modelling (extended abstract)
Willemse, Tim
Model Based Tesing of a WAP Gateway
Hessel, Anders and Pettersson, Paul
SAT-based Verification of LTL formulas
Zhang, Wenhui
Evaluating quality of service for service level agreements
Gilmore, Stephen and Clark, Allan
Test Coverage for Loose Timing Annotations
Maraninchi, Florence and Helmstetter, Claude and Maillet-Contoz, Laurent
BLASTing Linux Code
Muehlberg, Jan Tobias and Luettgen, Gerald
On Combining Partial Order Reduction with Fairness Assumptions
Cerna, Ivana and Brim, Lubos and Simsa, Jiri  and Moravec, Pavel
An easy-to-use, efficient tool-chain to analyze the availability of telecommunication equipment
Siegle, Markus and Lampka, Kai and Walter, Max
Goanna -- A Static Model Checker
Huuck, Ralf and Fehnker, Ansgar and Rauch, Felix and Lussenburg, Michel and Jayet, Patrick
Verified Design of an Automated Parking Garage
Mathijssen, Aad and Pretorius, A. Johannes
To Store or Not To Store Reloaded: Reclaiming Memory on Demand
Weber, Michael and Hammer, Moritz
Verifying VHDL Designs with Multiple Clocks in SMV
Smrcka, Ales and Matousek, Petr and Rehak, Zdenek and  Safranek, David and  Vojnar, Tomas and  Rehak, Vojtech
Automated Incremental Synthesis of Timed Automata
Bonakdarpour, Borzoo and Kulkarni, Sandeep S.
A Finite State Modelling of AFDX Frame Management using Spin
Roy, Suman and Saha, Indranil
jmle: A Tool for Executing JML Specifications via Constraint Programming
Wahls, Tim and Krause, Ben
Discovering Symmetries
Saidi, Hassen
